Use the <named share profile> command to configure a specific AirDefense Radio Share profile. The <named share profile> refers to a specific AirDefense Radio Share profile, and moves you into the profile context that contains commands to configure a specific Radio Share profile.
The <named share profile> command is accessible from within the mitigator: shareprof context of the CLI.
Create <profile name> first and then move to the <named share profile> context to configure one to three AirDefense servers. Configure each server one at a time. You can also use the name command to rename the Radio Share profile and use the aplist command to add and remove AP39xx access points from the Radio Share profile.
After you run this command, run the apply command to implement the change.
