Use the show command to display DHCP (Dynamic Host Configuration Protocol) information for the specified topology. The show command is available from the topology:<named-topology>:l3:dhcp context of the CLI for b@ac, physical, and routed topologies.
The output of the show command is determined by how mode is set. See mode.
None
EWC.extremenetworks.com:topology:esa1:l3:dhcp# show DHCP option: local Gateway: 10.0.1.2 Address range: 10.109.1.2 10.109.1.254 exclude 10.109.1.5(interface address) DNS servers: Domain name: Max lease time: 2592000 Default lease time: 36000 WINS servers:
