Use the nasip command to configure the NAS IP address to be used with the RADIUS (Remote Authentication Dial In User Service) server being configured. The nasip command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
After you run the nasip command, run the apply command to implement the changes.
A.B.C.D | Specify the NAS IP address |
vnsip | Specifies that the VNS (Virtual Networks Service) IP address should be used for the NAS IP address |
The NAS IP address defaults to the VNS IP address if this command is not used to specify a NAS IP address.
You must be in RADIUS server configuration mode for the nasip command to be available. Use the config command to enter RADIUS server configuration mode. For more information, see config.
The following example sets the NAS IP address for this RADIUS server configuration to the VNS IP address for the cnl-AAA WLANS auth context:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# nasip vnsip EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply EWC.extremenetworks.com:wlans:cnl-AAA:auth# show nasip NAS identifier: Use VNS IP address
