Use the iot-application command to enable or disable the specific IoT application for the supported APs. The iot-application command is accessible from within the ap:<serial> context of the CLI.
| ibeacon | Configures AP as an Apple iBeacon. AP sends beacons in Apple iBeacon format. |
| ibeacon-scan | Configures AP to scan for Apple iBeacons. |
| thread-gateway | Configures AP as a gateway router for the Thread Network. |
| eddystone-url-beacon | Configures AP as an Eddystone-url beacon. AP sends beacon with an imbedded secure protocol URL. |
| eddystone-url-scan | Configures AP to scan for Eddystone-url beacons. |
Each supported AP can be configured for one application at a time.The following example configures the ibeacon mode for the IoT functionality on an AP3916ic.
EWC.extremenetworks.com:ap:1254Y-3211230000#iot-application ibeacon
The following example configures the ibeacon-scan mode for the IoT functionality on an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-application ibeacon-scan iot-ibeacon-scan-dest-ip 10.100.4.191 iot-ibeacon-scan-dest-port 5000 iot-ibeacon-scan-window 100 iot-ibeacon-scan-interval 100 iot-ibeacon-scan-min-rssi -100
The following example configures the thread-gateway mode for an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-application thread-gateway
The following example configures the eddystone-url-beacon for an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-application eddystone-url-beacon iot-eddystone-url https://www.abcdefg.com
The following example configures the eddystone-url-scan for an AP3915. The eddystone-url-scan command reuses the ibeacon-scan parameters.
EWC.extremenetworks.com:ap:1111111111113915# iot-application eddystone-url-scan iot-ibeacon-scan-dest-ip 10.100.4.191 iot-ibeacon-scan-dest-port 5000 iot-ibeacon-scan-window 100 iot-ibeacon-scan-interval 100 iot-ibeacon-scan-min-rssi -100
