Use the iot-thread-gateway-short-pan-id command to configure the IoT Thread Gateway Short PAN ID for the AP. The iot-thread-gateway-short-pan-id command is accessible from within the ap:<serial> context of the CLI.
<string> | A 16-bit, MAC-layer addressing field used in RF data transmissions between devices in a Thread Network. The default value is derived from the AP serial number. The Short PAN ID identifies the APs Thread Network. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command and specify the iot-application as Thread Gateway.
The following example sets the iot-thread-gateway-short-pan-id on an AP3915.
EWC.extremenetworks.com:ap:1111111111113915# iot-thread-gateway-short-pan-id 29EC
