Use the showvns command to display the VNS (Virtual Networks Service) names in the Wireless AP SSID list on the controller‘s user interface (Wireless AP screen). Use the no form of the command to remove the VNS names in the Wireless AP SSID list. The showvns command is accessible from the web context of the CLI.
After you have run the showvns command, run the apply command to implement the changes.
None
The following example displays the VNS names in the Wireless AP SSID list on the controller‘s user interface (Wireless AP screen):
EWC.extremenetworks.com:web# showvns
The following example removes the VNS names in the Wireless AP SSID list on the controller‘s user interface (Wireless AP screen):
EWC.extremenetworks.com:web# no showvns
