Use the default-topology command to assign an existing B@AC, B@AP, or routed topology as the default topology for the specified WLAN (Wireless Local Area Network) service. You can also use the default-topology command to unassign the default topology. The default-topology command is accessible from the wlans:<WLAN-service-name> context of the CLI.
For information about B@AC, B@AP, and routed topologies, refer to topology Commands.
Default topology name | Specify default topology to assign to the WLAN service |
none | Unassign the default topology from the WLAN service |
The following example assigns the topology FS-REMOTE to the WLAN service:
EWC.extremenetworks.com:wlans:gp1# default-topology FS-REMOTE
