Use the interim command to configure the RADIUS (Remote Authentication Dial In User Service) accounting server interim accounting interval. The interim command is accessible from the wlans:<WLAN-service-name>:auth context of the CLI.
interim-interval-value | Specify an integer value in minutes for the interim interval. The default value is 30 minutes. |
The interim command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For authentication mode command information, see mode. For mac command information, see mac.
The following example sets the interim value to 40 minutes:
EWC.extremenetworks.com:wlans:test:auth# interim 40
