Use the protocol command to set the authentication password for this site. The protocol command is accessible from the site:<named-site> context.
CHAP|PAP|MS-CHAP|MS-CHAP2 | Specifies an authentication protocol type. Valid values are CHAP, PAP, MS-CHAP, and MS-CHAP2. |
The CLI <named-site> context must be in config mode for a RADIUS (Remote Authentication Dial In User Service) server to execute the protocol command. Use the config radius name command to enter config mode. Use config exit to exit config mode.
The following example sets the authentication protocol to PAP:
EWC.extremenetworks.com:site:site1# protocol PAP
