Use the tagged command to enable or disable 802.1Q VLAN (Virtual LAN) tagging. The tagged command is available from the topology:<named-topology>:l2 context of the CLI for b@ap, b@ac, and physical topologies.
enable | Indicates that 802.1Q VLAN tagging will be enabled. |
disable | Indicates that 802.1Q VLAN tagging will be disabled. |
EWC.extremenetworks.com:topology:esa1:l2# tagged enable
