Use the vsa-ingress command to include ingress rate control information in the message to the RADIUS (Remote Authentication Dial In User Service) server. The vsa-ingress command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run this command, run the apply command to implement the changes.
enable | disable | Specifies to enable or disable the inclusion of ingress rate control information in messages to the RADIUS server. |
The vsa-ingress command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of ingress rate control information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-ingress enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-ingress Ingress as VSA attribute: enable
