Use the delete command to delete a RADIUS (Remote Authentication Dial In User Service) server configuration. The delete command is accessible from the vnsmode:radius context of the CLI.
RADIUS_server | Specifies the name of the RADIUS server to delete |
The following example deletes the RADIUS server named test-radius-server:
EWC.extremenetworks.com:vnsmode:radius# delete test-radius-server
