Use the show command to display RADIUS (Remote Authentication Dial In User Service) server configuration information. The show command is accessible from the vnsmode:radius context of the CLI.
RADIUS_server | Specifies to display information about the specific RADIUS server |
The following example displays a list of RADIUS server configuration information:
EWC.extremenetworks.com:vnsmode:radius# show Strict: disable Radius MAC format: 1. XXXXXXXXXXXX Client Access-Request includes Service-Type Attribute: disable Name IP address Protocol Retries(Auth:Acct) Timeout(Auth:Acct) Ports(Auth:Acct) Priority(Auth:Acct) RADIUS_1 192.0.1.202 PAP 3:3 5:5 1812:1813 1:1
The following example displays configuration information for the RADIUS server named “RADIUS_1”:
EWC.extremenetworks.com:vnsmode:radius# show RADIUS_1 Authentication port: 1812 Accounting port: 1813 Authentication priority: 1 Accounting priority: 1 Authentication total number of tries: 3 Accounting total number of tries: 3 Authentication RADIUS request timeout: 5 Accounting RADIUS request timeout: 5 Interim accounting interval: 30 Default protocol: PAP Shared secret: ********** Name: RADIUS_1 Radius IP: 192.0.1.202
