The radius-timeout-policy command within context wlan:<WLAN-service-name>:auth sets the specified policy from the list of configured policies to apply when the authentication request to the RADIUS (Remote Authentication Dial In User Service) server times out. By default, the treat-like-access-reject policy is applied when authentication requests time out.
After you run the protocol command, run the apply command to implement the changes.
policy name | Specifies the name of the policy to apply when an authentication request times out. |
treat-like-access-reject | Specifies that the authentication request be treated as an authentication failure when the authentication request times out. This is the default. |
The following configurations must already be in place before this command is available:
See role_commands for creating and naming policies.
The following example selects the p6 policy to apply when authentication queries to this RADIUS server time out:
EWC.extremenetworks.com:wlans:new-wlans:auth# radius-timeout-policy p6
