802.11h support on the Wireless Appliance will allow clients to operate with the maximum available transmission power in 5Ghz bands. The 11h-support command is accessible from the wlan:<WLAN-service-name>:rf context of the CLI.
Use the 11h-support command to enable 802.11h support on the WLAN (Wireless Local Area Network) service.
After you run the 11h-support command, run the apply command to implement the changes
enable | disable | Enables or disables 802.11h support on the Wireless Appliance. |
The following example enables 802.11h support on the WLAN service:
EWC.extremenetworks.com:wlans:test:rf# 11h-support enable EWC.extremenetworks.com:wlans:test:rf# apply EWC.extremenetworks.com:wlans:test:rf# show 11h-support Enable 11h support: enable
