Use the capture-duration command to specify the capture window. The default value is 5 minutes.
number of minutes | Packet transfer window. Default value is 5 minutes. |
The capture-duration command offers a way for you to limit the length of the packet capture. This command limits the capture to a specified number of minutes. Maximum Packet Count max-packet is another method of limiting packet capture. Or, simply use the stop command.
The following example sets the duration on a wireless AP3912i to 5 minutes:
EWC.extremenetworks.com:ap-traffic-capture# capture-duration 5
