The scprof command moves you to the scprof context, which contains commands to create and delete In-Service scan profiles. AP models AP37xx, AP38xx, and AP39xx are supported. The scprof command is accessible from the mitigator context of the CLI.
InService profile can do Rogue AP scanning as well. Rogue scanning can be enabled after Security scan has been enabled.
The following commands are available in the mitigator:scprof context:
