Use the radio2-strictlimit command to enable or disable strict enforcement of load limits on Radio2. When enabled, any clients in excess of the configured limits on the radio are immediately disconnected. The radio2-strictlimit command is accessible from the site:<named-site> context.
enable | disable | Enables or disables the strict enforcement of load limits on Radio2. |
Radio Load Control must be enabled for this radio before this command can take effect.
The following example disables strict load limiting on Radio2:
EWC.extremenetworks.com:site:site1# radio2-strictlimit disable
