Use the status command to enable or disable OSPF (Open Shortest Path First) advertising on the port.
enable | Indicates that OSPF advertising will be enabled |
disable | Indicates that OSPF advertising will be disabled |
The following example enables OSPF advertising on the port:
EWC.extremenetworks.com:ip:ospf:ospfinterface:top1# status enable
