Use the create command to create a WLAN (Wireless Local Area Network) service configuration. The create command is accessible from the wlans context of the CLI.
WLANS-name | Specifies the name of the WLAN service |
mode (mesh|wds|std|3pap|remote) | Specifies the mode of the WLAN service |
ssid ssid-string | Specifies the SSID of the WLAN service |
hs-type (enabled|osu) | Specifies whether the WLANS is a basic hotspot or an online signup hotspot. To enable hotspot, the mode must be std or remote. The WLAN Service status for new hotspots is disabled by default. To enable the WLAN Service, you must first configure the privacy and authentication settings. Once the hotspot is configured, the hotspot type cannot be modified. If you need to modify the hotspot type, you must create a new WLANS. |
The following example creates and then displays the details of a WLAN service hotspot configuration named hs-wlan in std mode:
EWC.extremenetworks.com:wlans# create hs-wlan mode std ssid hs-wlan hs-type enabled EWC.extremenetworks.com:wlans# hs-wlan EWC.extremenetworks.com:wlans:hs-wlan# show Service type: std Hotspot type: enabled Name: hs-wlan Enable/disable WLAN Service: disable Remotable: disable Inter-WLAN Service Roaming: enable Associated WLANs: hs-wlan Egress Filtering: disable
