Use the mfp command to configure MFP. The mfp command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI.
require | enable | disable | Sets MFP to require, enable, or disable. |
The following example enables MFP on the WLAN (Wireless Local Area Network) service:
EWC.extremenetworks.com:wlans:AZ-723-WLAN1:priv# mfp enable
