Use the enable command to enable and configure SNMP (Simple Network Management Protocol).
none | Disables SNMP |
(v1v2|v3) | Enables either SNMPv1/V2 or SNMPv3 |
contact | Specifies the name of the SNMP administrator |
location | Specifies a description for the location of the SNMP administration machine |
rcommunity | Specifies a name for the read-only network management community |
rwcommunity | Specifies a name for the read-write network management community |
1 | Forwards the SNMP trap with the Critical severity level |
2 | Forwards the SNMP trap with the Major severity level |
3 | Forwards the SNMP trap with the Minor severity level |
4 | Forwards the SNMP trap with the Informational severity level |
5 | Forwards the SNMP trap with the Trace severity level |
1-65555 | Specifies the destination port for the SNMP traps |
The following example enables SNMPv3:
EWC.extremenetworks.com:snmp# enable v3
