Use the ap command to configure packet capture on a specific AP.
serial | Specifies the serial number of the AP. After you have specified the AP, configure the packet capture parameters. |
all | Configure packet capture for all APs in the network. If this option is specified, you must use a filter command. |
The following example configures packet capture on the wireless AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# ap serial 3912000000000000
