Use the timeout-pre command to set the pre-authentication timeout value (in minutes) for this WLAN (Wireless Local Area Network) service. The timeout-pre command is accessible from the wlan:<WLAN-service-name> context of the CLI.
After you run the timeout-pre command, run the apply command to implement the changes.
0-999999 | Specify the pre-authentication timeout value in minutes for this WLAN service. |
The following example sets the pre-authentication timeout value to 10 minutes for this WLAN service:
EWC.extremenetworks.com:wlans:test# timeout-pre 10 EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show timeout-pre pre-authentication timeout(minutes): 10
