The default-role command moves you into the vnsmode:default-role context. The default-role replaces the former default-policy of previous releases. The vnsmode:default-role context provides commands for the configuration of the default-role.
The default-role definitions provide a placeholder for completion of incomplete (no-change) roles (policies) for the VNS (Virtual Networks Service) being configured. Refer to role Commands for a complete discussion of role commands.
The default-role specifies:
After you complete configuration changes for the default-role, run the apply command before exiting the vnsmode:default-role context to implement the changes.
The following commands are available in the vnsmode:default-role context:
