Use the radtest_login command to check the RADIUS (Remote Authentication Dial In User Service) server‘s configuration. The radtest_login command is available from the login:auth context.
user name | User Name required to log on the controller |
password | Password required to log on the controller |
The following example tests the RADIUS server‘s configuration:
EWC.extremenetworks.com:login:auth# radtest_login admin abc123 ==> called pam_start (1) got success ==> called pam_authenticate got: ‘Success‘ RETURN VALUE: 0 resp.code: 0 Test Result: Success
