The defaults command moves you into the defaults context, which contains commands to configure the Wireless AP‘s default settings. The defaults command is accessible from the ap context of the CLI.
As the Wireless APs discover and register with the controller, they inherit the properties of the default Wireless AP setting. Since these defaults must apply to multiple AP platforms, they consist only of values that are supported on all platforms. To apply options individually to an AP, you can modify the default Wireless AP settings on that AP either via the Wireless Assistant GUI or the CLI <serial> context.
The commands are case sensitive.
Print
this page
Email this topic
Feedback
