txbf
Use the
txbf command to enable or disable the 11n advanced TXBF feature. The
txbf command is accessible from the ap:defaults: context and the
ap:<serial> radio contexts for the following AP models:
- ap37xx
- ap38xx (radio 2)
- ap3801 (radio 2)
- ap3935 (FCC, ROW, IL, radio 1)
- ap3965 (FCC and ROW, radio 1)
- ap3912 (FCC, radio 1)
- ap3915 (FCC, radio 1)
- ap3916 (FCC, radio 1)
- ap3917 (FCC, radio 1)
The available parameters depend on the AP type and the radio.
txbf enable | disable or txbf mu_mimo | disable for AP39xx
on Radio 1.
Usage
Only AP37xx supports antenna selection. When TXBF is enabled, antenna
selection must be left-middle-right.
Parameters
enable |
Enables the 11n advanced TXBF feature. |
disable |
Disables the 11n advanced TXBF feature. |
mu_mimo |
Sets TxBF to MU-MIMO. |
The following example enables TXBF on radio1:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# txbf enable
