Use the foreign-range command to configure the DHCP (Dynamic Host Configuration Protocol) pool of addresses for a remote Wireless Appliance in a paired controller configuration. The foreign-range command is available from the topology:<named-topology>:l3: dhcp context of the CLI for b@ac and routed topologies. This command is visible only when mode is set to local. See mode.
A.B.C.D | Specifies the first IP address in the IP address range. |
A.B.C.D | Specifies the last IP address in the IP address range. |
The following example specifies the IP address range:
EWC.extremenetworks.com:topology:routed2:l3:dhcp# mode local EWC.extremenetworks.com:topology:routed2:l3:dhcp# foreign-range 10.44.6.2 10.44.6.254
