Use the mode command to configure the authentication mode for the WLAN (Wireless Local Area Network) service. The mode command determines which authentication commands are available.
The mode command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
For information on the captive portal context, see default-topology.
After you run the mode command, run the apply command to implement the changes.
disabled | Disables authentication modes |
8021x | Enters the 802.1x authentication mode |
internal | Enters the internal captive portal authentication mode |
external | Enters the external captive portal authentication mode |
guestportal | Enters the guestportal captive portal authentication mode |
splash | Specifies the guest splash captive portal authentication mode |
external-by-firewall | Enters the external by firewall authentication mode |
You can configure the external-by-firewall parameter with additional commands.
add-ap-name-sn | Enable or disable adding AP name and serial number to redirection URL. |
add-bssid | Enable or disable adding associated BSSID to redirection URL. |
add-ip-port | Enable or disable adding IP and Port to redirection URL. |
add-mac | Enable or disable adding User's MAC address to redirection URL. |
add-role | Enable or disable adding currently assigned role to redirection URL. |
add-sign | Enable or disable adding signature to redirection URL. |
add-time | Enable or disable adding timestamp request received by controller to redirection URL. |
add-vlan | Enable or disable adding containment VLAN (Virtual LAN) (if any) of assigned role to redirection URL. |
add-vns | Enable or disable adding VNS (Virtual Networks Service) Name to redirection URL. |
apply | Apply the command setting. |
cp-https | Enable or disable https support. |
end | Return to the base mode. |
exit | Return to the previous mode. |
extredir | Set external redirection URL. |
extsecret | Set the Shared Secret password. |
fqdn | Set the string to replace the Gateway IP address with a FQDN. |
identity | Set Identity. |
logout | Logout. |
send-login | Type of CP redirection URL. |
show | Display settings. |
The following example sets the authentication mode to external captive portal:
EWC.extremenetworks.com:wlans:test:auth# mode external EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show mode Authentication mode: external
