Use the non-auth command to change the default role for non-authenticated clients. This command is available from the vnsmode:<named-VNS> context.
After you run the non-auth command, run the apply command to implement the changes.
role-name | Specifies the name of the role to use as the default role for non-authenticated clients. |
When you change the default non-authenticated role for this VNS (Virtual Networks Service), the same rules apply as when a VNS is created. That is — if the VNS‘s WLAN (Wireless Local Area Network) Service has a mode of:
The following example specifies that the role named “non-auth-users” should be used as the default role for non-authenticated users for the VNS named VNS1:
EWC.extremenetworks.com:vnsmode:VNS1# non-auth non-auth-users EWC.extremenetworks.com:vnsmode:VNS1# apply
