Use the acws command to enable or disable Active OBSS Channel Width Adjustment. The acws command is accessible from within the ap:<serial> context and ap:<defaults> context of the CLI.
enable | disable | Enables Active OBSS Channel Width Adjustment. |
AP38xx and AP39xx models support ACWS. An overlapping BSS coexistence scan runs when a radio configured to 40 or 80Mhz starts. The scan ensures that newly started radio beacons do not overlap secondary channels of active radios. By default, this option is enabled for newly deployed APs and is disabled for existing AP deployments, ensuring backward compatibility with previous ExtremeWireless releases.
The following example enables Active OBSS Channel Width Adjustment on an AP3915.
EWC.extremenetworks.com:ap:3915000000000000#acws enable EWC.extremenetworks.com:ap:3915000000000000# apply
