Excessive packet capture degrades network performance. When enabling packet capture on all APs, specify at least one MAC address filter to avoid performance degradation.use-filter-ip1 enable | disable to use-filter-ip4 enable | disable | Use the
use-filter-ip1 to use-filter-ip4parameters
to enable or disable the IP Address filters.
The following example applies the filter-ip1 filter on a wireless AP3912i:
EWC.extremenetworks.com:ap-traffic-capture# use-filter-ip1 enable
