interface
Use the interface command to specify the interface on which the exception traffic is to be captured.
interface interfacename
Parameters
interfacename The interface name on which the exception traffic is to be captured. You can choose any of the following interfaces:
The following example specifies the exception traffic to be captured on esa0:
EWC.extremenetworks.com:traffic_capture# interface esa0
