Use the status command to enable or disable the OSPF (Open Shortest Path First) protocol on the Wireless Appliance.
enable | Indicates that the OSPF will be enabled |
disable | Indicates that the OSPF will be disabled |
The following example enables OSPF on the Wireless Appliance
EWC.extremenetworks.com:ip:ospf# status enable
