Use the <named ad profile> command to configure a specific AirDefense profile. The <named ad profile> refers to a specific AirDefense profile, and moves you into the profile context that contains commands to configure a specific AirDefense profile.
The <named ad profile> command is accessible from within the mitigator: adsprof context of the CLI.
Create <profile name> first and then move to the <named ad profile> context to configure one to three AirDefense servers. Configure each server one at a time. You can also use the name command to rename the AirDefense profile and use the aplist command to add and remove AP39xx access points from the AirDefense profile.
After you run this command, run the apply command to implement the change.
