Use the show command to display the <named-cos> configuration information for the current cos:<named-cos> context. The show command is accessible from within the cos:<named-cos> context.
None.
The following example displays the my-cos CoS (Class of Service) configuration from within the cos:<named-cos> context:
EWC.extremenetworks.com:cos# my-cos EWC.extremenetworks.com:cos:my-cos# show Name: my-cos Use Legacy Priority Override defined in the WLAN Service: disable 802.1p Priority: none ToS/DSCP Marking: Mask: Inbound Rate Limit: Outbound Rate Limit: Transmit Queue: none Synchronize: enable EWC.extremenetworks.com:cos:my-cos#
