Use the capture-wired command to capture packets from a wired port. You can specify a specific AP or not. If you do not specify a specific AP, you muse use the filter options.
Excessive packet capture degrades network performance. When enabling packet capture on all APs, specify at least one MAC address filter to avoid performance degradation.enable | disable | Enables or disables wired packet capture. |
The following example captures packets from a wired port on an AP3912:
EWC.extremenetworks.com:ap-traffic-capture# capture-wired enable
EWC.extremenetworks.com:ap-traffic-capture# ap 1111111111113912
