Use the ospf-cost command to set the OSPF (Open Shortest Path First) route cost value. The ospf-cost command is available from the topology:<named-topology>:l3 context of the CLI for routed topologies.
After you run the ospf-cost command, run the apply command to implement the changes.
| 1-50000 | Specifies the OSPF route cost value. |
The following example sets the OSPF route cost value to 6000:
EWC.extremenetworks.com:topology:r1:l3:# ospf-cost 6000
Print
this page
Email this topic
Feedback
