Use the iot-ibeacon-major command to configure the ibeacon Major — Identifies a subset of beacons within the larger set. This value could represent a venue specific attribute, such as a specific store or wing in a building. Valid values are 0 to 65635. The iot-ibeacon-major command is accessible from within the ap:<serial> context of the CLI.
<0, 65535> | A 2-byte string that identifies a subset of beacons within a larger set. Enter a value between 0 and 65535. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin before issuing this command.
The following example sets the iBeacon Major on an AP3916ic.
EWC.extremenetworks.com:ap:1254Y-3211230000#iot-ibeacon-major 100
