Use the antsel command to configure the antenna combination you want to use for the radio. The antsel command is accessible from the ap:defaults: ap37xx, as well as ap:<serial> CLI contexts for all 37xx APs, except for ap3705.
After you run this command, run the apply command to implement the change.
left | Specifies the use of the left antenna on the AP. |
left-middle | Specifies the use of the left-middle antenna combination on the AP. |
left-middle-right | Specifies the use of the left-middle-right antenna combination on the AP. |
The antenna options available depend on the type of AP and the radio. We support: left, left/middle, and left/middle/right on many APs. This is not supported on the AP39xx.
The following example depicts Radio 2 of the Wireless AP37xx AP configured to use the left-middle-right antenna combination:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio2# antsel left-middle-right
