Use the port command to configure the port number used for rogue detection on the AP. The port command is accessible from the mitigator:scprof:<named scan profile> context of the CLI and the mitigator:gsprof:<named guardian scan profile> context of the CLI. (Guardian also scans for Rogues.)
The port command is only available if security scan is enabled.
| port-number | Specifies the number of the port used for rogue detection on the AP. Valid port numbers are 1-32768. |
The following example specifies port 1538 as the port used for rogue detection on the AP for the scp_name scan profile in-service:
EWC.extremenetworks.com:mitigator:scprof:in-service# port 1538 EWC.extremenetworks.com:mitigator:scprof:in-service#
Print
this page
Email this topic
Feedback
