Use the elocation-support command to enable or disable reporting to ExtremeLocation™.
The elocation-support command is accessible from within the elocation context of the CLI.
enable | disable | Enables or disables reporting to ExtremeLocation™. |
The following example enables ExtremeLocation:
EWC.extremenetworks.com:location:elocation# elocation-support enable
