Use the wlans‐list command to assign Radio 1 and Radio 2 of APs to specific WLAN (Wireless Local Area Network) Services. For APs with client ports, you can assign 1 - 3 port numbers to the service. See Usage for more information. Use the no command to remove radio assignment from specific WLAN Services. The wlans‐list command is accessible from the ap:defaults context of the CLI.
After you run the wlans‐list command, run the apply command to implement the changes in radio assignments.
wlans-name | The name of the WLAN service. |
radio1 | 5GHz radio. |
radio2 | 2.4GHz radio. |
p1 | p2 | p3 | Specifies
the client ports on the AP3912 to assign to the WLAN service. Note: The camera on the AP3916 always
connects to p1.
The following example assigns Radio 1 to CNL-209 WLANS:
EWC.extremenetworks.com:ap:defaults:assign# wlans-list CNL-209 radio1
The following example assigns P1 to CNL-209 WLANS:
EWC.extremenetworks.com:ap:defaults:assign# wlans-list CNL-209 p1
