Use the status command in the vnsmode:<named-VNS> context to enable or disable the current VNS (Virtual Networks Service).
After you run the status command, run the apply command to implement the changes.
enable | Enables the VNS. |
disable | Disables the VNS. |
This example disables the current VNS named VNS1:
EWC.extremenetworks.com:vnsmode:VNS1# status disable EWC.extremenetworks.com:vnsmode:VNS1# apply
