Use the mode command to change the mode of an existing b@ac, b@ap, fabric, or routed topology. You can configure the mode of a topology only if the topology is not associated with a policy. The mode command is available from the topology:<named-topology> context of the CLI for b@ac, b@ap, fabric, and routed topologies.
b@ap | b@ac | routed | fabric | Specifies the mode of the topology. |
The following example changes the mode of the topology to b@ap:
EWC.extremenetworks.com:topology:bridged_ac1# mode b@ap
