Use the vlanid command to configure the VLAN (Virtual LAN) ID of a physical topology or change the VLAN ID of b@ac or b@ap topologies. The vlanid command is available from the topology:<named-topology>:l2 context of the CLI for b@ac, b@ap, and physical topologies.
1-4094 | The VLAN ID that you want to assign to the topology. |
This following example sets the VLAN ID of the topology named test to 2:
EWC.extremenetworks.com:topology:test:l2# vlanid 2
