Use the create command to create a topology object. The create command is accessible from the topology context of the CLI.
topology name | Specifies the name of the topology. |
b@ac | Specifies a Bridge Traffic locally at Controller topology. |
b@ap | Specifies a Bridge Traffic locally at Access Point topology. |
routed | Specifies a routed topology. |
physical | Specifies a physical topology. |
vlanid | VLAN (Virtual LAN) ID assigned to this topology. Value can be in range 1-4094. |
tag | untag | Specifies tagged or untagged VLAN. |
port port-name | Specifies the name of the layer 2 port. |
A.B.C.D/0-32 | Layer 3 IP address and mask assigned to this physical topology. |
fabric | The Fabric Attach topology type allows an AP to attach to a Shortest Path Bridging (Fabric Connect) Network. The client component on the AP communicates directly with the server on an edge switch (or it can communicate with the server through a proxy) to allow the AP to request VLAN to I-SID (backbone Service Identifier [IEEE 802.1 ah] mappings). The Fabric Attach topology type is similar to B@AP with the added I-SID parameter. Fabric Attach can be configured on a controller anywhere a B@AP topology can be configured. |
isid | I-SID (Service Identifier [IEEE 802.1 ah]) |
The following are available topology types:
IPv6 is supported for Layer 2 bridging for both B@AC and B@AP topologies.You can choose from the following topology types (modes) when creating a topology:
Only B@AC, B@AP, Fabric, and Routed topologies can be assigned to policies.
The following example creates a B@AC topology named bac1, with a VLAN ID of 2, using the esa1 controller port:
EWC.extremenetworks.com:topology# create bac1 b@ac 2 port esa1
EWC.extremenetworks.com:topology# create fabric1 fabric 1234 tag isid 12
