Use the iot-ibeacon-scan-dest-port command to configure the destination port used to reach the customer Application Server. The iot-ibeacon-scan-dest-port command is accessible from within the ap:<serial> context of the CLI.
<0, 65335> | Configures the destination port used by the ExtremeWireless AP to reach the customer's Application Server. Valid values are: 0 to 65335. Default value is 0. |
The IoT functionality is supported on the AP3912i, AP3915, AP3916ic, and AP3917. Enable iot-admin and iot-application ibeacon-scan before issuing this command.
The following example configures the ibeacon-scan-dest-port on an AP3912i:
EWC.extremenetworks.com:ap:3912000000000000#iot-ibeacon-scan-port 100
