Use the move command to change the order of authentication modes in the authentication mode ordered list.
order | Specifies the current priority of the authentication mode. |
Use the show command to view the priorities of the authentication modes. See show.
The following example changes the authentication mode order from local, RADIUS (Remote Authentication Dial In User Service) to RADIUS, local:
EWC.extremenetworks.com:login# show 1 authentication method: local 2 authentication method: radius EWC.extremenetworks.com:login# move 2 1 EWC.extremenetworks.com:login# show 1 authentication method: radius 2 authentication method: local EWC.extremenetworks.com:login# apply Changing login mode will cause CLI to terminate. Do you want to proceed? [y|n]:y ************************************************************ Login mode has changed. CLI will terminate in 5 seconds! ************************************************************
